Exhaust system/Warranty
  Recaro + Cupped 182
Hello,
If i fit an exhaust system on my 182 will it void the remaining warranty?
Ive heard that if you change suspension or chip it you can lose the remainder of your warranty.
  BMW M3
I think they have to prove that it had a direct impact on the failed parts, causing them to become faulty prematurely.
  Rsport182Cup'd
depends, if you break car then change exhaust back if you are worried before going to dealers, before i had my sport i had a dynamique lowered exhaust ibduction etc etc and it went in for warrenty work done no probs, i think it is more to do if your mod causes the problem, like put stiff springs on then you cause dampers to break they will not replace dampers etc etc
MRBILLYUK
  FF Jeden Osiem Dwa
The only part of your warranty that will be affected is the warranty on your exhaust . The rest of your warranty will still be valid .
