Expert help needed on wheel fitment
  VW Golf S 1.4
quote: The front wheels are 7 1/2 J x 18 ET 50 and are fitted with Michelin Pilot Sport 225/40/ZR 18
The rear wheels are 9J x 18 ET 52 and are fitted with 265/35/ZR 18
These came off a porsche 5x130
i have a VW golf mk4 5x100 and know that i can get pcd adaptorts from venom sport that will conver 5/100 to 5/130 and correct centre bore etc but im a little confused with the offset business can anyone tell me if there is going to be a problem with a 25mm pcd adaptor and these wheels??!!
Da
  Less
The fronts will sit 15mm further out and the rears 17mm further out than standard.
  lift number 1 @ btm
so, assuming the wheels clear the arches ok. you can use spacers if you need to move them out a bit. just remember you'll need longer bolts too!
  Breaking A 172 Replica
As Daz + Fred said but...
Won't the PCD converters act as massive spacers? I think they will both sit very far out of the arches and I would have thought you'd certainly need your arches rolled.
Sam
  lift number 1 @ btm
^ i've just realised that too! with 25mm pcd converters the fronts should be 10mm out and the rears should be 8mm out.
  lift number 1 @ btm
you might get away with that, you need to measure the clearance as it is now. might be worth taking the car to a decent garage and asking too?
  VW Golf S 1.4
cheers for the advice, theres these real nice porsche bbs wheels i want on ebay at the moment and they finish tomoro :dapprove: so i dunno what im going to do!!!
  lift number 1 @ btm
i know a lot of people use the porsche wheels on vw's, try calling jabbasport, awesome gti, c&r or prabably venom themselves. there will be someone at one of them with the answer, and in my experience they are all very helpfull.
