Ultra Red Clio 197
Right,
Basically the other day I changed my exterior door handles over to new colour coded ones.. was an easy enough task and everything worked perfectly when I finished... The next day I unlocked the car using the central locking went to pull the drivers side door handle and it wouldnt work.. I went around to the passenger side and it worked fine. I reached accross and opened the drivers side door from the inside.. walked around the car closed the door and when I tried to open it again it worked.. I then locked the car, then opened it and again the drivers side would not open...
OK.. so I have narrowed it down to possibly somthing faulty with the central locking... It seems that when the car is opened witht the central locking somthing isnt working so that the drivers door is unlocked... this is hard to explain, but hope you get the idea.. Does anyone know what I have done or if I have knocked something off when changing the handles? Its really starting to bug me that to get in the drivers side I have to reach accross from the passengers side!
When can I do to sort out this problem?? Has anyone else ever had the same problem?
Ross
Mods:: please delete other thread..
Ross
