Recently replaced PAS Pump and High pressure pipe after it blew on me whilst driving ?? and ever since then, the engine bay as a whole is Extremely hot and I mean not just engine, pretty much everything in the engine bay is too hot to touch for at least half an hour after turning off the ignition.
Could this be an issue with the water pump after having the aux belt off and back on?
Thermostat issue?
Hole in exhaust manifold?
There's no clear signs of why its overheating which is making it difficult, the engine gets up to temp fine and the needle stays in the middle, oil level is spot on, coolant level is spot on although I removed the coolant cap after 10 mins of the ignition being off and steam came out?
Any suggestions would help massively!
Cheers guys,
Louis
Thermostat issue?
Cheers guys,
Louis
