Thanks, I'll try to look it up.Don’t know the size but here’s the number
8200110994
Thanks , but I'm not sure what you meant by that.They’re the same size as the 1*2 item.
John
So fat it looks like 60 mm for the VDO replacement.Don’t know the size but here’s the number
8200110994
They all share the same throttle body, so the size of the butterfly is the same across the range. 60mm is the diameter of the standard butterfly.Thanks , but I'm not sure what you meant by that.
John
Appreciate it, thanks!They all share the same throttle body, so the size of the butterfly is the same across the range. 60mm is the diameter of the standard butterfly.
