F4r cam cover bolts
hardy
  Clio Mk1 Track Proj
Hi all,
Does anyone know of anywhere to get hold of the cam cover bolts that hold the cam cover to the head which aren't directly from Renault?
Has anyone used any normal bolts instead of the Renault ones?
Cheers,
Josh
hardy
  Clio Mk1 Track Proj
Long as they are the same grade / length any other bolts should do the job?
This is my thought exactly. Just wondering if anyone else has done the same sort of thing?
hardy
  Clio Mk1 Track Proj
Which ones do you need?
Definitely a couple of the smaller ones and one of the bolts that hold the breather plate to the cover.
I will find out how many more when I take the cover off to get one of the snapped ones out.
I gather you will have a few in stock?
