FabRS74 car's - Only trackdays
Hi everybody,
I'm Fabien alias FabRS74 on the net, i'm moderator on ClioRS-concept.com and i'm coming here for presente to you my toy for trackday.
Sorry for my bad English:approve:
Clio RS1 2000 Grey and Orange touch'
Engine
- Collector 3y
- New admission
- Plenum retaillé
- Cale RS
- Calculator GRN
- Décata Inoxline
- Inter tube inox
- Support engine Strengthened K-Tech Racing
- Reprogramming MD Racing
- Régulateur pression essence 3.5 bar
- Pare chaleur moteur tôle
- Récupérateur de liquide de DA
Chassis
- Thread receiver(combined competition) GAZ
- BAR OMP avant
- BAR OMP arrière
- Arch 6 points ORECA
- Kit train avant Powerflex
- Biellete de couple Powerflex
- Silentbloc crémaillère CUP by Seiz
- Berceau soudé
- Disques AV Brembo Max
- Plaquettes AV Pagid RS14
- Plaquettes AR Mintex 1155
- Lockheed RBF 600
- Durites avia
- Jantes 15" OZ F1 semi-slick et 15" Dial slick Dunlop
- Cales BRATEX 16mm AV/AR
- Cales pentées AR 1°
- Vis excentriques Monroe AV -3°
- Ecopes de freins dans AB by Juju
- Déflecteurs de freins style 16s
Esthtétique
- Bequet Compet
- Suppression EG arrière
- Antenne courte
- Crochet Cup AV et AR
- Masques de phares
- Déco fun circuit Gris/Orange/noir
Habitacle
- Steering wheel SABELT Renault Sport de Clio Cup
- Bucket seat RRS Futura
- Harnais 4 points RRS
- Emptying high level
- Door panel fiber
- Battery(Drum kit) in the safe(chest)
- Deblaxonnage interieur complete
- Relieved dashboard
- Block ventilation(breakdown) light
General lexicon on ClioRS-concept
Thank you for your acceuil
Hi everybody,
Engine
- Collector 3y
- New admission
- Plenum retaillé
- Cale RS
- Calculator GRN
- Décata Inoxline
- Inter tube inox
Chassis
- BAR OMP avant
- BAR OMP arrière
- Berceau soudé
- Lockheed RBF 600
- Durites avia
Esthtétique
- Bequet Compet
- Antenne courte
- Masques de phares
Habitacle
- Door panel fiber
- Volant tulipé
- Vidage Stage 1
- Baquets RRS Futura
- Speedline Rallye 15"
- Anneau Cup
- Speedline + RRS
- Goujons 80mm
- PC arrière RS1
- Cales pentées 1°
- Déblaxonnage arrière
- Vidage + déblaxonnage + berceau tombé + boite sortie + vidange boite/moteur
- Plaquettes avant + panneaux de portes + remontage intérieur
- Support moteur K-Tech + Clim OUT + batterie dans coffre + plaque mano/lève vitres
- Train avant + bielette Powerflex
- Nettoyage papillon + embrayage monté
- Boite remontée
- Joint carter d'huile + remontage total (berceau, intérieur, moteur...)
- Vis excentrique Monroe
- Nouvelle déco
- Volant Sabelt Renault Sport
- Nouvel intérieur et TDB provisoire
- TDB light-bloc ventil light-Pack slick orange
- Préparation montage arceau
- Masques de phares
- Soudure arceau
- Peinture arceau + préparation caisse
- Montage arceau
