failed mot
ourboy
Car  172 cup
failed mot today due to front coilover springs loose when car was jacked up .
I have GAZ coilovers fitted and don't have my car droped very much around 35mm but it looks like i will have to rise it to put pressure on the springs.
has anyone else had any experience like this ?
thanks
is it common for the spring to be loose when the car is raised off the ground?
if i lower the car in the future will it be a case of having to raise it for mot each year?
if the cars still sitting near o/e height on the coilovers then you should have helpers in there, otherwide the distance from spring platform to top cap on full shock piston extension will be bigger than the height of the uncompressed spring, hence its loose
so other option is to wind the coilovers down (in ride height) until the springs are tight when the cars jacked up, ten minute job provided they arent seized
