Isnt the compression ratio a combination of the head, pistons, crank and blah blah. Not really sure hehe. Capt could you please grace us with your wisdom
the 172 pistons and willy pistons r useless on the stock 1.8 crank, because theyd stop about 5mm from the top of the bore! so id need a 2litre crank. i can keep the same rods, jsut use 2litre crank and pistons.
if they stoped short of teh block then that would mean willy/172 pistons have a lower crown right?
so, the 1.8 pistons give a higher comp ratio if used on the 2ltr crank right?, the willy/172 pistons would give stock 2ltr compression on the 2ltr crank then!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
