FAO Clio Geniuses
Rob
Ok, I'm going to need a proper clio geek for this.
I've just recieved a new seat bottom, I was just going to use the cover (as I burnt mine :eek:) but it seems to have been removed from the top half of the seat without damaging a thing.... now, my question to you all:
How do they come apart and is it something I can change out as one? (foam and everything)
Or do I need to go with my original plan and take the cover off etc??
  Megane 225 F1
If you take the seat out, and wind it back as far as it will go, you may be able to see where they join? I don't know, I'm no genius :D
  Golf GTD Mk7
Guessing, I'd imagine you'd have to remove the cover. Not sure how easy that is. Then remove the piece you want, and replace. It's hard to picture what you're changing :S Pics?
Rob
Well I have a whole seat bottom. The cover and the foam. (no runners, seatbelt or anything)
I did plan just to use the actual cover, i.e the piece of material, but the sponge seems to have been seperated with no damage, so I was thinking I could just change the whole bit over, rather than just the material which is a pain in the ass to do.
I'll take some pics tmrw if it's necessary.
  Golf GTD Mk7
So you have the whole bottom with the metal bits also? Have you removed your seat to see if they are easy enough to seperate? You'll just need to be careful with the release wire i'd imagine.
