Dont know a whole lot about the plate systems, but if youre on carbs theres not much else you can do. Logic would suggest that a plate system hooked up to carbs would deliver the nitrous better than a single injector upstream of the throttle body (as for a fuel-injected system).
Trev (Trevor Langford) is the best guy to ask questions to. He is unquestionable the most knowledgeable person in the country on NOS (possibly the world. I kid you not), and runs/owns Highpower systems. (I have one of there kits on my Cosworth)
the plate system (BTW m complltly pissed so i might ramble) is ajust a plate a few mm thick with a howwol bar goin across from one side to the other. it has holes in and sprays the n20 down the manifold. its mounted between the carm and manifold.. there ok.
on my carbed MK1 XR2, i use a single crossfore injector mounted 3/4" above the primary venturi to spray down the carb throat, ensures even distrubution.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
