Fault Codes
Car  2007 Clio
Hey, I had my engine management light flashing today.
Car stuttered a bit and then it flashed.
Faults are
random/multiple misfire
low fuel detected (there was a 1/4 tank in it)
2007 1.4 renault clio dymanique UK
edit: it's at 44k miles and had some coils replaced a few months back.
I've had this before on a K4J powered Megane II... Turned out to be the MAP sensor but I'm not saying it will be in your case and really you should have it properly looked at.
Hi mickpm. my brother in law had his code reader plugged in and looked at "live data" and revving the engine made the MAP sensor go up and it came down as the revs dropped if that means its working ok i dont know.
Maybe your coil packs? Mine was similar to this when I was mis firing and it was coilpacks
Ive had ignition coils replaced and I swapped them around and it got no better or worse. Real pain in the arse.
Had it at a garage and the guy said "Well, yea, idk whats wrong with it" awsome.
I don't know anyone around here (Glasgow, UK) that will fix the damn car instead of ripping me off and/or talking shite about possible fixes/faults.
I'll be damned if im giving it to Arnold Clark also.
Does anyone know of a garage in Glasgow (even scotland) that will know the problem and fix it?
I really wish I was closer to you MickPM :( You seem to be someone I really need right now!
Cheers.
