Few electrical faults
Car  2000 Clio 1.2
Hi, I have three things up with my car (2000 1.2) :(
The first one is the service light and seatbelt light coming on. I've read about the connector under the passenger seat and sprayed some WD-40 but it still comes on but not all the time.
The next is the speedo is intermittent. It always works when I first get in but sometimes it just drops down to zero and can stay there for miles, others its just for a second.
The third is my washer jets. The wipers work fine but the jets don't spray front or back.
Any ideas what to check to fix them?
Thanks in advance, Carl
To perminantly fix fault 1 you will have to cut the grey and yellow conectors out from under the seats and solder the wires together.
Fault to will be the speedo transducer in the back of the gearbox. Do a search it has been covered many times.
Washer jets could be a muiltitude of things from blown fuse to a faulty pump.
