fibreglass sub box
Looking great there!
the amount of layers depends on the weight of matting your using, but it should be about 1cm - 1.5mm.
Once its strong enough ie over 1cm all over, you will be able to stand on it without doing any damage!
You could sandwhich corematt
http://www.cfsnet.co.uk/acatalog/CFS_Catalogue__Coremat_30.htmlhttp://www.cfsnet.co.uk/acatalog/CFS_Catalogue__Coremat_30.html
but this needs to be between say 5mm of FG either side as its not as strong.
http://www.cfsnet.co.uk/acataloghttp://www.cfsnet.co.uk/acatalog - is a good place to get it, and cheap (if buying reasonable quantities)
HTH
Rorrie
  Polo + Micra
nah that was just the time i posted this:) .
rorrie did you mean between 1-1.5 mm or cm?
they are 12" holes. the dimensions im not sure of but i think it might be between 1.7 - 2.3 cu.ft.
yer sorry was meant to be cm!
as for the box, quite a good shape! im thinking of doing my boot build with plenty of fg still but i need more sapce in my boot, as there is none!
i may build it in the space tyre (where the tools usually are), hum, sorry getting of topic!
