Evo 6 TME, Clio 172
Hi all my car idles badly and intermittently cuts out when stopping, there's no fault codes showing, so got no clues there. It's had new plugs and post cat lambda in last 6 month's as they were faulty but didn't cure the cutting out issue.
I've seen people say check for air leaks, what's the easiest way to do this? I've done boost leak checks on previous turbo cars by using a compressor, can I do the same on these? Or is there other ways
It's had a head gasket before so makes me think lower inlet gasket could be the issue, heard there awkward to get off, is this the same on a 172 cup with different aux belt set up?
Sent from my SM-G950F using Tapatalk
