First Detail [First ever use of DA] Honda CTR [Pic Heavy]
I used my DAS6 for the first time over the weekend, on my cousins Civic Type R. Got a new camera and took lots of photos and thought I'd make a little write up.
Was hard work, but enjoyed it, and thoroughly rewarding at the end!
Had a few little niggles, that'll just come with experience I guess, but overall pretty happy with my first attempt.
Big thanks to everyone on here who has helped me in terms of advice on products and techniques!
Before pics:
DSCF4067 by James.Rawlins, on Flickr
DSCF4068 by James.Rawlins, on Flickr
DSCF4069 by James.Rawlins, on Flickr
DSCF4070 by James.Rawlins, on Flickr
DSCF4071 by James.Rawlins, on Flickr
DSCF4072 by James.Rawlins, on Flickr
DSCF4073 by James.Rawlins, on Flickr
Stage 1: Decontamination
First up I pre-rinsed with Daisy APC diluted, and washed using Dodo BTBM and the 2BM.
DSCF4074 by James.Rawlins, on Flickr
Next up I sprayed on some Tardis, before leaving it to dwell and wiped with MF applicator pad, wasn't to bad for tar:
DSCF4075 by James.Rawlins, on Flickr
Next up applied Wolfs Deironizer, quite a few spots came up, and left to do its work before washing again, with Megs Gold class and the 2BM.
DSCF4077 by James.Rawlins, on Flickr
Also tackled the wheels whilst the Wolfs was doing its work, used Daisy APC diluted, and De-ironizer/Tardis. In need of a refurb really.
DSCF4078 by James.Rawlins, on Flickr
Next up, once I'd shampoo'd off the Wolfs, It was time to clay, with a Megs Clay bar and diluted Demon Shine as lube. Even though I'd de-tarred/de-ironed it was still lifting off a fair bit of contaminants
DSCF4079 by James.Rawlins, on Flickr
Finally, after completing the final shampoo, car was dried with drying towel and taped up ready for polishing
DSCF4081 by James.Rawlins, on Flickr
DSCF4080 by James.Rawlins, on Flickr
Stage 2: Polishing
Paintwork wasn't actually in to bad condition, not many swirls I could see:
DSCF4082 by James.Rawlins, on Flickr
So then cracked on with the polishing. Used Mezerna PO 106 FA and a combination of Green and White Hex Logic Pads.
Started off at slow speed for two or so passes, then stepped the speed up and did a further 6 or so passes, or until the polish was worked in:
DSCF4090 by James.Rawlins, on Flickr
Shot after just polishing:
DSCF4093 by James.Rawlins, on Flickr
After going round the car, I then moved onto Glaze. Used Britemax Blackmax and a Blue Hex Logic pad, on slow speed for a few passes. Loved using the glaze. So easy to put on and barely any excess to remove.
Shot after polish/glaze:
DSCF4094 by James.Rawlins, on Flickr
Stage 3: LSP
Finally as LSP I used AG HD wax. Left for 15 mins then buffed off. Found it quite hard to buff off, don't know if it was the heat, or too much product, or a combination of the two. Probably should've done smaller areas too.
DSCF4095 by James.Rawlins, on Flickr
DSCF4096 by James.Rawlins, on Flickr
Finally, Polished the glass by hand, dressed the plastics with AG Vinyl and Rubber care, and used Megs Endurance Tyre Gel on the tyres.
I ran out of time at this point, so didn't get to finish a few things I'd have like to, but took a few pics anyway.
Quite pleased with the results for my first time, obviously on a steep learning curve, and could've been better, but my cousin was over the moon with it, and apparently has been receiving a lot of glowing comments. Looking forward to doing my car next and improving further!!
Didn't really achieve much in the way of correction, but did bring out the shine in the paint and no visible swirls, a few deeper scratches in the clear coat I couldn't get out, but am still quite happy.
Finished:
DSCF4097 by James.Rawlins, on Flickr
DSCF4112 by James.Rawlins, on Flickr
DSCF4111 by James.Rawlins, on Flickr
DSCF4110 by James.Rawlins, on Flickr
DSCF4109 by James.Rawlins, on Flickr
DSCF4108 by James.Rawlins, on Flickr
DSCF4107 by James.Rawlins, on Flickr
DSCF4106 by James.Rawlins, on Flickr
DSCF4104 by James.Rawlins, on Flickr
DSCF4103 by James.Rawlins, on Flickr
DSCF4101 by James.Rawlins, on Flickr
DSCF4099 by James.Rawlins, on Flickr
DSCF4098 by James.Rawlins, on Flickr
Before pics:
Stage 2: Polishing
Stage 3: LSP
Finished:
