I had DIY fitted the Group N ECU last night. It is same as the BB Tuning one. Feels GOOD at all range of driving. Both the rev and the throttle response go up faster. Was trying to get to near 7.8k rpm but the engine sound a bit loud and I was thinking if the engine can handle that .
About the fitting, it was not hard except the removal of the ECU cover which is made by iron or steel. It was so hard to remove even with screw driver. Main thing is that I was afraid of damaging the existing ECU. Also I have to remove the strucbrace in order to remove the ECU. But glad that mine are OMP and it has 3 sections. I only have to remove the top bar, not the circle part that is screw on top of the front suspension mount.
Putting back the ECU cover is an hassle which I had gave up. Therefore, I dont have any strucbraceat the moment.
BUT I do have 2 little problems after fitted which I am wondering if any other member are same???
1) The idle is strange whenever I stop the car. I knew it will get up to 1.2k. But the problem is when I almost fully stop the car and I step onto the clutch, the rev will go up a bit to 2K rpm. It will hold a while, back down little by little after I fully stopped and released the clutch. This may hold for 3-5sec which is so strange. I am wondering if it is because I am using factory panel filter (my K&N is in cleaning and I will fit the ITG Maxogen soon). Will that effect the air/fuel ratio balance??? What should I do? I have to use cone filter? It is a bit annoying be honest, even there is no problem when driving with great response.
2) How to reset/unlock the stereo??? It require 4 digital number. How do I enter and where can I find the pin number for my stereo?
Well, your advice are very important
thanks!
