Fitting kit for alloys!
ok what is this? sorry dumb question?
i know you get em for steerin wheels, but if im gettin 37mm offset wheels for me cup, i wont need em will i?
  Clio 200 FF
Fitting kits are more for universal wheels (tsw,etc). You can get a different diameter ring to put in the wheel center to change the hub fitment, this is just a plastic ring which pushes in and can be changed.
Also some companies relate a fitting kit to - wheel bolts / nuts (ford use a dome shaped nut for alloys and flat for steel wheels), locking nuts / bolts
if thee wheels youre getting are the correct PCD and Offset then you wont need a fitting kit
  Lionel Richie
Danny, theyre ET37 4x100 PCD
The fitting kit for SuperLs consists of 4 centre rings (have to be specifically for Renault) and 16 shinny new wheel bolts
THANKS FRED! So everyone who has bought Supers need the plastic fitting rings yeah? and do renault sell em? but i can use my normal nuts from my old wheels tho cant i?
  Clio 200 FF
the rings should have been supplied with the wheels, maybe there already in the wheel centres? , theyre not renault parts
they are called spigot rings aint they. and yes you do need them. I fitted the wheels without them at first and the car didnt run "true". As soon as they were fitted th car ran like a dream.
If you buy some without them get your local alloy wheel firm to order you a set, shouldnt cost more than about £10, if that.
