Fitting Samco Coolant hoses & Bleeding the coolant system
  182, SQ7, Trafic
Right few things. Have the ProAlloy rad I'm fairly sure it doesn't have any bleeding facilty on it. I've been told that filling the coolant reservoir then squeezing the pipe and repeating that until the squeezing pushed the water higher is the best way?
Also, how much coolant/water do I need? Whats the best stuff to use?
  182, SQ7, Trafic
O RLY?
I think on my valver it was on my rad and just assumed the same :)
Cheers Fred!
M
mini-valver
Its a 10mm at the top, facing right as you look down at it. Bang some water wetter in their while you're at it, being charged.
  340i
you will just about get 5L back in the system...
Drain with thermostat bleed screw open
Flush with hose pipe
Fill with Renault Type D coolant
get it up to temp
thermostat will then open and coolant level should go down in the reservoir
Top up
Repeat
And repeat
Something along those lines anyway ;)
Just check it for a few days after as the level may drop slightly
  182, SQ7, Trafic
Cheers Gray! Its one of those things I've never had to really do or thought of before!
