fitting time ?
Not that long 4 hours maybe its an unusal bits what is the new wishbone is the old one broken and what does the nati roll bar consist of a new anti roll bar will tane longer than just some bolts to the hold the anti roll bar to the suspension arm.
depends how good you are with cars mate.obviously you'll do the wishbones at the same time as the anti roll bar so your probobly talking an hour or two.if my experiences are anything to go by though(unless theirs some kind of special tool)you'll spend a while trying to get the inner and outer bushes on the roll bar compressed enough to fasten them.the inner ones are fiddly might be easier if you could get your car on a ramp
if your fitting the anti roll bar bushes made by powerflex measure the inner ones before you fit them as some 172's and 182's are fitted with a fatter 28mm front anti roll bar. where as others i have seen are fitted with 25mm and 23mm bars
