FK coil suspension, any got?
FK's are great, either highsport or konigsport depending if you want adjustable damping and want to pay the extra for it.
They come with speay can of lube and spanner don't round off the fixing nuts unlike some brands (according to place thet fitted mine)
I've had mine for over 2.5 years and other than making sure you clear the springs out of grit now and then they are great. They use a helper spring so guess its like having 2 spring rates.
They are TUV approved which means they should have been designed on the car and tested on it. They should also come with lifetime warranty but this may be dependent on getting fitted by an authorised FK fitter.
Think there are some good deals on FK's so probably get for a lot cheaper than Ktec who aren't the cheapest place you can go to.
lol AJR
I don't particularly want to buy from k-tec as I personally have had a few bad experiences with them and there prices are outrageous AND they are just pants to be honest.
For £600 are they are best coils you can get for my car? 70mm drop is a fair bit; will I be able to manage over speed bumps ECT?
Thanks Matty, appreciate it.
Adam
Neva had a problem with k-tec it was them that organised ourr crackin group buy for 463£!!!!! this yr,
The ones at £350 will be for the valver/williams models mate, just two front springs with torsion bar on the rear IIRC.
