Flashing immobiliser light when turning the key in ignition??
  Black 182 Cup
Not sure what the problem is here but pretty regularly the immobiliser light flashes and the engine won t start. Prob happens twice then the engine will start.. any ideas??
Try the other key otherwsie your trying to turn the key to quick or the picup ring needs chnaging round the ignition barrell
As above if the other key works then you got a faulty key if neither work then its the ring round the ignition barrel
