flat battery replacement
i think my battery is flat, it has been going for quite a while and never got round to getting a new one as i dont drive alot at uni, but it needs doing now.
how easy is it to remove and has anyone got a step by step guide because i had a quick look and am not sure!
also, i have an amp and new speakers, and an in car phone and headset charger so i am wanting a slightly better battery to deal with this draw of power, any suggestions?
cheers jamie
Yeh i got the same problem
How much are batteries + where can i get one from
Needs to be able to handle my amp, sat nav etc!
does it just lift out fred? looks like its in a case. . . . never changed it before as this is my first car. cheers
not hard at all mate, as fred said 8mm spanner and a 13mm socket on an extension, the case also has a few bolts to hold the battery in place, thats what you need the extension for, loosen the battery case and lift off
on the right hand side of the battery if you look down you'll see the clamp and 13mm bolt holding it in
just lifts out
i'll get you the spec off my battery, give me 10min
