flat spot and judder?!
Car  197
Ive had this happen for a few weeks now. When i get upto around 4000rpm or set off in first gear at a low amount of revs my car judders or takes a while to climb revs. It also does it if im in to high a gear. Its not as if the car's struggling with it being in a high gear, its as if it misfires then judders.
Anyone else had the same problems? I was thinking spark plugs but im not a mechanically minded person so i need another persons input pls! Ive also had a little search before posting but im shite at searching stuff!
Cheers in advance
Chris
Mine does this when i drive through big puddles to soak the local chavs :D
Soon dries out and runs fine though.
Also could be a dodgy coil pack :)
Cool thanks for the quick reply. Im looking at getting it serviced by kwik fit at the end of the month. Would they be able to resolve something like this if i put it to them or is it worth asking around?
when i bought the car about 2 weeks after i bought it the plugs went but dont know if the guy who i bought it off replaced the lot. 2 of the plug caps are different which i have noticed.
