right! disconnect the bottom hose on the radiator let all the fluid run out. when it stops put a hose in the header tank let it flow through the system until onlt clean water comes out.
when you are filling it up you only have one bleed screw on the top of the radiator on the right hand side.
u33db : hard to say as when I got it off paul he had put the flush in so I just had to change it for proper coolant when I got back to aberdeen. It was running hotter with the flush but I think thats probably as its not as good as proper coolant...
Im not to sure about disposing of it, it was raining and I just did it on the main road then washed it away with a hose pipe lol.
Drain the system from the bottom hose, disconnect the top and use a hose to flow water through it. When all the crap stops flowing through it and clear water comes out, put your hand over the bottom exit and fill it up, then empty it. Continue to do that as the hose doesnt clear everything.
THen place the hose into the bottom coolant hose going towards the block, and flush that out, then do the expansion bottle.
Fill it up with water and coolant system fush, run it for a bit (at least until the fan comes on and off 3 times). Then drain, do the same and fill with the proper D type coolant.
to properly flush block, undo block drain hose which is under exhaust manifold, awkward to get to but possible, think its 15mm and its on crankshaft (drivers side) pulley end of engine. I changed my water pump and put a low temp thermostat from bbpt. Car now runs at first quarter to half, rather than half to three quarters, much better, recommend this for cooler running, decent coolant is a must on F7 engines me thinks
