fog dash lights flicker
Car  172 cup
when i brake the fog lights on the dash flicker. will that be somethin to do with the rear lights connections?
hi there mate
i had the same problem on my 1.2
if it the same problem there can be many causes
if you remove the rear light/s and disconnect the loom from the back of the bulb holder you should notice that 1 of the pins has managed to melt the plastic which surrounds the pins i will take picture tomorro if it helps...
all i done was got to undamaged bulb holders from a scrapyard and the problem was solved it only cost a fiver.
