fog light help???
Car  Racing blue 182 turbo :-)
How do i wire up my fogs to come on at the same time as my main beam, but make it so when i put my fogs on, on there own they don't turn main beam on???
Get a 5 pin relay.
A new wire from the feed to your fog lamps to term 87
A new wire from the headlight supply at the switch to term 30
A new wire from the main beam output from the headlight switch to term 85
A new wire from term 86 to earth.
It can all be done at the lighting switch behind the steering column shroud.
Do it this way and you can still use the foglights as before.
Principle is the same for most cars, not at all chavy Tom, makes better use of the foglights than using them for "driving" lamps and pissing everyone off, and unlike that misuse, perfectly legal.;)
