fog light
Car  clio 172 sport
Hi i have a problem where when i press the brake the fog light flickers on the dash has anyone else had this problem an what fixed it if you have thanks
It's a poor earth in the rear lights, easy to sort.
Take the rear lights out and disconnect the board the bulbs go in to.
Get some sand paper and clean all the contacts on the board (both where the bulbs clip in and where the wiring block connects)
Gently bend all the connections out a little with a small screw driver to ensure they all have a good connection and reassemble.
Should have sorted out the flickering light.
