Front caliper sticking
Car  172 GTR
My nearside front caliper is sticking. If I jack up the front end I can hardly turn the wheel but the off side spins freely.
Any suggestions?
Danny
Check the pads are correctly seated. Peal back the rubber dust covers and grease all the sliders.
did you change the pads and whilst the front end was off the ground tried to see if it was breaking properly? if so 1 side will not spin until its on the floor and your moving,
I've took the caliper off and manually pushed in the piston. Re fit caliper. Wheel back on and it spins ok. Drive round block. Jack it up wheel stiff to turn again.
Caliper fcuked!
Caliper fcuked!
Did you remove, copper grease and test the slider to see if thats free?
