Front Components & Tweeters
  Clio 197 R27 Albi
Right time has come to upgrade the front components in my 182. i know the correct sizes and power ext its the fitment which is a problem. I've done a quick search and it seems to be a worry for quite a few clio owners. Havent found the answer I want though.
I can work out how to fit the bottem speakers, but will I be able to fit the new tweeters in the dash? how easy is it to take the orignal ones out? any information on fitment would be appreciated. also any genral tips on fitment would be great. Thanks
  Clio 197 R27 Albi
anyone fitted upgraded speakers. i dont wanna cut wires and mess with stuff before i know what im doing.
  RIP MK2 PH1/1.4 16v Polo
have you thought about leaving your old tweeters in and putting some more tweeters in at the top of the pillar or something?
im sure someone will be able to help you out more
  182
I fitted tweeters in my 182 with no problem. You twist the grills to get them off and you prise the old tweeters out. :cool:
  Clio1.2 16v & LR Defender
The standard tweeters are a terrible. I took mine out by opening up the grill. Snipping the wires and prying them out with a screwdriver. I havent replaced them as they dont make alot of differance.
I would advice removing them but not adding new tweeters.
If you see me ill be around Mutley plain area. I havent got my cliosport sticker yet as still waiting for it from membership pack. :)
  Evo 8 MR
That's just typical chav rubbish.
Remove the top part of the dash and replace them.
  RSC 182 Cup
Yes, the dash top isn't very hard to remove and then you can do a proper job and replace them with something decent.
There was a guide but the site has closed. I think there might be something in the member's section???
  182
There really is no need to remove the dash. Way OTT. I've just fitted a set of rainbow components in my 182. The old tweeters prise off really easy. The new ones can just sit in their place in you can run new cable down the dash to a crossover.
