Front Fog light relay
Hi gents,
I have a 2002 1.2 Dynamique and was wondering if someone could tell me where the front fog light relay is? My bulbs are ok, but when I crank the stalk switch, they don't come on. The rears do work ok though.
Thanks in advance.
i knw where the relay is for the lights on the 2001 clio,( behind the glove box)
on the 2002 it a UCH thing.
best option is take the fuse cover of the passenger side part of the dash when you open the door and look at the back of the cover and it should tell you which fuse is which( check the one that corresponds to the fogs, check the fuse and see if its blown) as to the relay, i have a haynes manual but i cant understand the diagrams)
UCH on the 2002 is aparently just the fuse box and relays combined, on earlier models they where separate according to this manual.
ok. so if the fuses are ok,
have you a multimeter to hand?? switch the fogs on, go the the front fogs, pull the wire off and test if you are getting any dc voltage, ( if any) at those points.
Right, Ive got no dc voltage going to the connectons on the rear of the fog units. The bulbs are fine. If on mine, the fuse box and relays are combined, I take it there are no other relays to check? I searched all over and can't see anymore. I have voltage coming off the fuses for the rear (obviously as these work ok).
Any other ideas at all? When I turn the swtch on, the icon on the dash for the fronts does not illuminate, but it does for the rears.
hum, this is a tricky f***er to sort. so the fuses have voltage, rear fogs illuminated ok, but no sign on cluster of fronts fogs even turning on....
seems as mine hasn't gone tits up yet, i haven't really had the time to take apart and fine the source of the problem i would say theirs only two options left unless any one else knows,
either call an auto electrician to have a look
or
take the car down to Renault or other specialists garage and get it sorted. only problem is that it might cost a fair bit, seems as labour costs are mental
This has recently happened to my 2002 dynamique 172 rep! must be a replica fault! haha. Its not the bulbs that are faulty. its the fuse as the light on the dashboard does not light up when swithched on.
My car does this too!!! Its a 52 dynamique, bought it accident dammaged from a lad at work who hadnt claimed on it.
It had been sitting a while so battery and altenator were buggered, my electrics came on when i was driving but went of when i came to stop lol.
Anyways on the off chance in the first 3 days before i got it sorted it decided to work all the electrics were fine, front fogs and rears and h/ls and everything.
Next day it went to auto electricians, since then fogs havent worked =(.
I noticed few days ago that one bulb wasnt fitted so went to local parts seller n they wanted £10 per bulb!!!
So made a trip to eBay lane n got full hid rep bulbs for full front end for £10 ;).... But still no work =(
P.S anyone know anyone who is cheap at fixing dints and spraying in north-east?
