Front Fog lights help
  clio 182 full fat
Not long had the car its a 182, the light comes on the dash but the fogs dnt come on :S. Could this be a relay if so where do I look, I use Google and found not a lot so could you guys help please
  172 Ph1/Scooby MY00
On my Ph1 172 this was due to the connector by the horn not making good contact. Do the wire wiggle test to see if the lights come on. A fix is to squeeze the connector with grips to make a better contact.
LB197
Could just be a fuse, theres also a loom that joins them both togeather that connects into the main loom, check there both plugged into the lights and that the main loom connector just behind the bumper (under the bonnet) is connected to the main loom
