thatflookguy
172 Cup & 172 Turbo
Looking for some help, for ages now the rear fog lamp symbol lights up on the dash when braking, started as a flicker and now is full on.. Kinda ignored this and now I find my hazard lights flash all the time which of course runs the battery flat.
Done the usual,
Removed the hazad switch,
Cleaned up the earth points on the rear lights going to the body,
Checked the pins in the bulb holders and replaced all bulbs,
Cut the connectors off each light cluster loom as I have bought genuine Renault repair loom (not soldered in yet)
Replaced the number plate light and connector with new loom.
By removing the fuse for the hazard lights now the left indicator symbol lights up when braking.
When the hazards flash there is no clicking unless the ignition is turned on, checked the alarm and it works along with the siren.
Front lights, wipers etc work as normal, so not sure where to look as something is running to ground but between 2 circuits and earth.
Is there a common issue within the wiring harness where something is damaged or where should I now look to resolve this?
Can I confirm the brake pedal switch on the 172 Cup in the 4 terminal white connector?
Done the usual,
