Front Fog Lights - Won't Turn On And No Light On Dash
Car  172 Cup
Problem is pretty much as the title goes.
When switching the front fog lights on with the stalk they aren't turning on and no light is on the dash, and the rear fogs work fine.
Could it possible be a fuse or has the switch goosed on my stalk?
Bark x
Another one!
Try the fuse and the Relay but I doubt that will fix it, it's either the wiring or as you say the switch on the stalk - I'm having the same issue with mine
I thought I was going to be left trying to find out by myself for a bit there!
I'll have a nosey tonight see what's going on.
Failing that CAF's FTW :)
How did you find out about yours like Daz.?
Mine was working fine one moment then cabbaged the next!
Would explain why my car feels like it's lost power then Tony ....
Actually noticed due to getting quite a bit of fog up here no charva antics going on here!
Same just stopped working - was checking all bulbs for mot - even though you don't need them for mot, I just don't like things that should work not working... Regardless of whether I use them or not they should work!
Mine didnt work the other morning? Then I switched the headlights on via the stalk (were already on auto) and they worked no prob! ;)
Just noticed you had replied sorry dude.
Mine was due to a relay being faulty under the passenger side of the dash.
Now the ball and chain's car has the same problem. Checked the relays and they all seem fine, just need to get the fuse checked then see what the crack is.
