Front Fog lights
AK
  M240i
Where can i pick up front fogs for my Mk3? And how much can i expect a garage to fit them for?
Is it easy to convert them to standard road lights, is it just a case of changing bulbs or is there a bit more in it than that? :)
Renault dealer is going to be your best bet. don't know how easy to fit they might be
if by 'standard road lights' you mean driving lamps, it won't be possible to convert them as the lens/reflector design dictates the light pattern that the lamps emit - fog lamps will only cast light onto the road directly infront of the car and you cannot alter the beam pattern unless you fit different lamps
might be worth asking if Renault can obtain the same lamp but in a driving/spot lamp pattern
