Front Fog Wiring
Anyone know how this works?
Is there two seperate plugs on the main loom going to each fog light?
Or do they have the own loom which then plugs into the main loom?
I can only find one plug in my engine bay which looks like it could be for fogs? ( I wanna wire my fogs up finally but didnt have them originally!)
Thanks.
You have a 16v tho, so you can see whats already there!
Go and Look! Heh.. I wanna know how the fog lights connect up.. :)
there is one loom, on the passenger side on the facelift model anyway, which leads to an empty relay socket in the engine, id assume you pop in the relay, wire up the fogs to that and wire a new switch
Not sure on the valvers, but on the phase 3s theres a spare loom just behind the the drivers headlight. one +ve and one -ve wire thats all. link that up to fog, then double it off to run the second fog, running the wire to the second fog down in front of the radiator, just inside the front bumper.
Whip out the fake switches on the right side of the steering wheel. Behind there should be a 6 point connector which leads to that loom.
Conect that to a switch. Got my renault switch from a scrappy.
Also. Put a yellow fuse for the front fogs in the auxilery fuse box, along with the correct relay in the passenger fuse box.
Job done.
Thats what I thought - so there is one wire for the fogs.. which splits to both of them.. easy. Ill get that done then - I wanna get me 4 fogs wired up.. been foggy loads lately.
Thanks.
