Front fogs don't work
Car  182, SQ7, Trafic
Any ideas? Fuse is fine and wouldn't of thought both bulbs would of gone :s
Do you really care that much matey??
I can count on my one hand the amount of times i've actually had to use fog lights in the 5 years i've been driving..
Yeah they're useless anyway. If mine broke, I wouldn't fix em.
Check the fuses first, then bulbs, then wiring, then forget about them if you can't fix them.
Does the picture come up on the dash? If they've both gone it points to being a stalk/wiring fault rather than both bulbs. First thing I'd do is see if the block plugs are getting a feed (use a testlight from the market or whatever for less than a fiver if you like or a multimeter)
Then go from there.
Light on dash comes on yes!
Not really bothered by them just want everything working really :)
If you have auto lights, you have to turn them on as though you would in a normal car then turn the fogs on ;)
