Fuel problem?
  Clio 182
Hi, been having a few idle problems with my clio 182, Very low idle speed and when driving feels like its running out of fuel when accelerating?
Pre-cat lamba appears to be ok (recently changed) and have checked all injectors which appear fine. Any ideas?
  Clio 182
I've checked them all changed the coil, all appear fine? No air leaks either.. doesn't do it all the time, only after starting, and intermittent during.
  Fiesta ST2 MP215
You check leads with a multimeter? your descp sounds more like it's running on 3 under load rather than out of fuel.
  Clio 182
doesn't feel or sound like its running on three but I will have to check, thanks
Is there anything else I could check? why would the revs be sitting so low?
  Fiesta ST2 MP215
How low are they sitting, mine sat just under 800 prior to the RS tuner ( which is an utter pain in the clunge btw article to follow tomorrow on this ) and that sorted it right to 1000RPM and made it run so so so soooo much better all round. How long you had the car for?
