fuel sender resistance
  dan's cast offs.
If you get stuck, give me a shout. I've recently finished mine and it's a bit of a pain
spoke to one of the guys there and sounded easy enough but i could of misunderstood him though :wink:
he said there is diagram on their site on how to set it up.
vroomtshh
  Seat Ibiza Cupra TDi
There is, it's the Renault side of it that's a pain. Have you got pull up resistors? You'll need to earth one of the wires from.the sender and then follow the diagram
vroomtshh
@bloke have you wired the standard temp sensor to a dash 2? Just wondering if you know if its resistance based
  dan's cast offs.
nope, hooked it up to the can output on the sc ecu. don't think you can hook the dash 2 up to standard sensors? sure i remember them saying it has to use their own sensors?
vroomtshh
That's what I would like to do but it doesn't work with the ME ecu. You can use any sensor. You just need to know how the sensor outputs. I thought it was a voltage based sensor, but it doesn't appear to be
  dan's cast offs.
are you sure? i know someone there did tell me it only works with their own? give them a ring and speak to sam, really helpful.
  Mk2 clio 1.2 16v
Hi I have a 2006 mk2 clio 1.2 and want to wire in a fuel gauge. But not 100% sure which one is the sender wire. Anyone got idea
