Fuse - Where is the reverse light fuse
  Skoda Fabia vRS
i cant find my haynes (blaming it on my mum tidying up)
anyone know where it is ?........
neither of my reverse lights work and ive tried changing the bulbs
  Skoda Fabia vRS
arse
and where would that be then ?
workin on the car is impossible without a Haynes !!.......
  Skoda Fabia vRS
fuse was ok............arse !
so wheres this switch then ?
can i get at it by removin the gear stick surround etc
  Skoda Fabia vRS
is it easy to replace ?
if i take it out, wil gear box oil come pourin out of the hole ?
  172 cup,s2 rs turbo
easy to replace and gear oil will pour out of the hole.
the switch is a simple on/off contact switch.remove the connector and bridge the wires(only two wires) using a paper clip. Do your reverse lights come on?(ing on remember)
  Clio 197
yeah in the haynes it sez you will need to drain you g/box oil before hand, dont bother if you change it quick you wont lose much fluid..it doesnt screw in that far either
its a little green thing behind the n/s driveshaft
  Skoda Fabia vRS
well mines got the GTT gearbox so its in a different place apparently, anywayz on tuesday im takin the induction kit out and intercooler if i have to, fittin a new silicone hose in there.........so ill have a look then when theres more room
  172 cup,s2 rs turbo
On the end of your gearbox there is a white or black metal cover which houses 5th gear. Underneath this housing screwed into the gearbox casing is the reverse switch. Its normally green or orange in colour.
