Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
easy to replace and gear oil will pour out of the hole.
the switch is a simple on/off contact switch.remove the connector and bridge the wires(only two wires) using a paper clip. Do your reverse lights come on?(ing on remember)
yeah in the haynes it sez you will need to drain you g/box oil before hand, dont bother if you change it quick you wont lose much fluid..it doesnt screw in that far either
its a little green thing behind the n/s driveshaft
well mines got the GTT gearbox so its in a different place apparently, anywayz on tuesday im takin the induction kit out and intercooler if i have to, fittin a new silicone hose in there.........so ill have a look then when theres more room
On the end of your gearbox there is a white or black metal cover which houses 5th gear. Underneath this housing screwed into the gearbox casing is the reverse switch. Its normally green or orange in colour.
