I dont think so? I know that mines only running around 7-8PSI and I was advised to put it on roller bearings if I wanted to run it much over.I thought people with S13's could run 1 bar/13psi happily on a STD tubby?
on a .49 houseing, a full t25/25 will handle circa 20 psi no problem at all, i used one on my first 5 turbo, running the above boost pressure.
it will make full boost silly early in the rev range and expect it to be on its arse after 4.5k rpm
My five had a T25 and it would run as much as the actuator would handle which was 34 psi. Turbo dynamics said it would run 15psi minimum but it was more like 18-19. Like you say hardley any lag it would be making boost at 1600rpm and by 3600rpm it would hit 34psi and hold 31-32.
That word "tubby" seems to get used to much, it sounds so gay, you make it sound like a girls toy,
