Gas Flowing or Port and Polish??
  Clio Trophy 463
Which do you guys think is a better gain for the money out of, Gas flowing or port and polishing??
Not quite sure of the differences...:eek:
I think there the same, gas flowing just means using a machine to work out flow rates porting and polisng etc is the modying of bits of the engine.
Best ask BenR or stan* though they'll know more.
  2005 Nissan Navara
both are generic "terms" for modifying the ports to improve gas-flow. polishing is often mistakenly used, as there is little polishing....the major work is the re-shaping of the ports. polishing is the final exercise on the exhaust ports and chamber...it contributes very little to the overall performance gain.
PM me for more info/prices
A million people use a million terms for what is essentially a modified cylinder head, so feel free to call it anything you want as a head specialist will know what your referring to.....within reason, ask him for beans on toast and you'll get just that.
Modification of cylinder heads is a highly specialised area and there is a grat difference between people who do average headwork (the majority) and jaw dropping headwork. Reputations can be misleading as i know many 'experts' in the field of cylinder heads and most of them i wouldnt give a tractor to.
Polising is a left over term from the 70's.......i dont know any decent specialist that polishes anything at all.
i dont like polishing ex and chambers due to the carbon thickness variations it leads to. The correct finish will support a uniform and self cleaning carbon layber which enhances combustion quality, thats just what i do and like.
  2005 Nissan Navara
fair point i guess
Fred2001Dynamic said:
where did you learn Ben? (serious question for a change!!)
i learned ben back in asia, its quite common for most oversea nationals to learn ben........infact, i dont know where i would be today without knowing ben, ben is the best..........
ladies love ben aswell, so knowing ben greatly helps in that department.
  93 rsi
to ben r
if you were having you head reworked, and you couldnt do it your self name 3 other places in the uk you would trust
erm...........
That is near impossible to answer.
Cylinder head specialists only really specialise in a few heads, or a marque. It takes lots of time to develop and continue developing a head, its not a matter of someone just being a good flow specialist, it takes time, testing and more time, lots of thought and sparks of eureka.
Someone who is s**t hot at a cosworth head will be almost usless on a honda because they follow entirely different port design theory.
However most great head people will be able to make any head flow better, but like i said, alot of the specialists make heads which would convince me to stick with std items.
