172 Cup
Hey Guys
So I've never been happy with the handling of my car, I haven't really paid a huge amount of attention to the set up as I've been looking to improve my own driving and tidy up the rest of the car!
I use my car on the road but also for hillclimbs/sprints
I've recently started looking into sorting the handling out and started by going for some softer springs as recommended by a couple of mates. While I've been stripping down the front coilovers I've found that the car has been bottoming out. Looks like once the car is on all 4 wheels I have about 25mm travel, which explains everything! Yes I know I really should of noticed sooner but I haven't adjusted the ride height since I fitted them to the car, when I did fit them I set them about 10mm off of the highest setting and gaz stated about 60mm of adjustment. So that's why I assumed that it wasn't bottoming out
So the issue I have is that effectively I seem to have no adjustment in ride height!?
I'm using kam racing adjustable top mounts and my only feeling with them is that they seem to have a lot of stack height, so between the 'top cup' of the spring and the chassis of the car I probably have about 40-50mm. But this is a set height and there's no adjusting that fact.
The car isn't low by any means, there's a pretty reasonable arch gap
So my question is has anyone has this issue before, have I done something really dumb, has anyone had issues with gaz gold set ups/kam top mounts etc
Hopefully I've explained my self well enough!
Any help or advice would be appreciated!
Rob
Rob
