M mark1111 Car 172 cup Apr 29, 2010 #1 I need some good spec shocks are gaz gold coil overs at the rear and how do you rate them
marinemackay2003 Car Supercharged Ph1 172 Apr 29, 2010 #2 i personally rate them quite well find the adjustable dampening very good, can go from soft to mega firm and quite a few clicks inbetween think they have 275lb rear springs so stiffer than most by 50lb apparently ps i got mine for free :rasp: along with the car:rasp: Last edited: Apr 29, 2010
ForceIndia Car Gentlemans spec 200 Apr 29, 2010 #3 You get what for you pay for. What will you be using the car for?
M mark1111 Car 172 cup Apr 29, 2010 #4 Trackdays and may be the odd sprint are they coilovers at the rear?
marinemackay2003 Car Supercharged Ph1 172 Apr 29, 2010 #5 no they are seprate shock and seprate spring with adjusters
drhowser Car lift number 1 @ btm Apr 29, 2010 #6 They aren't coilovers at the rear, but very few are. I found them to be very bouncy, as if the ratio between compression and rebound was wrong. for the money or slightly more, there is much better.
marinemackay2003 Car Supercharged Ph1 172 Apr 30, 2010 #7 on k-tec the b14,are only 100 more personally i would get them or better tbh especially if you will be competing ect as brow bear said you get what you pay for
