gear box ratio's
not using jc5 no. Spent months researching it and came up with a shorter 5th gear for ours (Race only)
There is lots available aftermarket but the way the box is made makes it very expensive as ratios cannot be changed individually (just 5th) so it needs a whole new shaft and costs £££££
If you go for something like a Gripper diff yes. again at a cost. There are alternate FD's available at around 1000 euros, not sure what diffs they fit tho. But there is no 'Stock' Renault ratio that is better than the 182 one. Bare in mind if you lower the FD ratio, 1st gear will be come almost useless
