Gearbox leaking oil!!
Tom
  i3
Again!!!!
Help!!
renault are tw*ts!!
this will be number 3 in 18months fom new!!
and its outta waranty cos i had i serviced somewhere else (stuipidly!! but my dealer was soo crap i didnt want to take it back)
Any ideas?
Tom
  i3
ok spoke to a mate the new one was fitted in april would there be a warranty on the replaced part?
  Clio II 1.4 Priveleg
You might not get a warranty repair as you dont get warranty on a warranty repair. If a vehicle is repaired during the warranty period, then the repair is only valid for the remainder of the original warranty period, not another 12 months. As you have taken your vehicle outside the Renault network for service/repair, your warranty is void anyway.
Soz to be the bearer of bad news.
Where is the gearbox leaking oil anyway? Selector shaft or n/s inner driveshaft boot ? These are the common sources of leaks.
Bob
  ICE'dberg MK2 172
Just because you took it else where doesnt mean you forefiet your warranty. As long as OE parts were fitted and you can back it up with invoices you should be OK.
Check with Trading Standards.
  Lionel Richie
Just take it to another Renault garage and act dumb!!!! There must be more than 1 renalut dearler daaaaaarn saaaarrrrrrrrrfffff!!!!!!!
Tom
  i3
Update:
The diff housing is cracked and the diff bearing is pressed in!!!
so basically its f**ked
In renault garage now awaiting inspection hopefully they will fix it for free!!
if not
Clio-spares
http://www.cliospares.co.ukwww.cliospares.co.uk Check the site out!!
Are going to do it for £250 all in
£150 for the box
£100 to fit it
So well done to them!!
