gearbox oil change interval?
Car  Megane 265 Cup
Can someone tell me what the gearbox oil change interval is in years/miles for a 182?
depends how much trashing you give the car. Track days cars it would be worth changing more often. Every 2 years I do now, depending on how many track days I've done. It's cheap to do, and quick, so why not? Especially as the JC5 does like to fall to bits ;)
the level or the oil?
Level check, all you do is remove the wing nut on the front of the box when the car is on the flat. The oil should be up to the bottom of the fill hole.
the gear oil level.
got a photo of said nut? not got a clue where it is
