Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
there appears to be some fluid loss from the gearbox, and looks like it is coming from where the left-hand driveshaft meets with the box. is it possible to remove the driveshaft oil seal on its own, or is it non-renewable (ie will i need a new driveshaft?).
yeah i thought about that, but it looks like it has been leaking for a good while, so ill prob drain the box and refill it. is it just the gaiter, so i dont have to buy a whole inner CV? but i assume still shaft out job to fit it?
btw cheers for your help chris, been spot on with all my qs!
just looked up the gaiter change in haynes, you need a press tho for the bearing in the gaiter right? are there any home ways for doing this, or is a trip down to the garage for just the press needed?
