Gen90 Problems with fuel pump
Car  Clio spor 172 Ph1
Hi friends, recently installed a gen90 in my clio 172 ph1 after moving the pins that they say does not activate the fuel pump, I read in the forum that several had this same problem, I would like to know what their solutions to this problem were.
Try connecting the original ecu again and if you activate the fuel pump
HELP ME! :(
HELP ME! 😧
Call ktec they will help
I already did, I'm waiting for you to connect by teamviewer, because they say that the base map is fine, I wanted to know the solution of those who had the same problem, but when I connect the original ecu the fuel pump if you activate
